Problem with 800
Old Sep 24, 2006 | 06:31 PM
POLARISSportsman500HO's Avatar
Default Problem with 800
I have a 2006 SP 800 and it has been great for about 500 miles. No problems until today when I was riding up in the hills in some snow I heard something that sounded like my belt was falling apart so I stopped and let it sit for a while and then headed back down before my belt was completly gone but now it was engaging fine however it still didn't seem to be running right so I stopped and check the oil and as soon as I pulled the dipstick out it was like exhast was coming out of the quad. Could it be gas in the oil? The other odd thing is that weather the quad is warmed up or cooled down(when I got home) it starts doing this right away? Any ideas what would cause this? Should I change the oil or just wait until tomorrow and take it to the dealer? It still has full power and the belt seems fine. Thanks in advance for the help.
Ty
Old Sep 24, 2006 | 07:01 PM
WHOLESALECIG's Avatar
MIGHT BE WRONG BUT SOUNDS TO ME LIKE YOU ARE GETTING COMPRESSION IN CRANK-BROKEN RING MAYBE??
Old Sep 24, 2006 | 07:09 PM
Smitty4's Avatar
If I understand you correctly, you mean you removed the dipstick to check the oil and saw some steam escaping the tube?
If that's the case (NO PRESSURE should release), that is normal, especially in cold temperatures. It's just normal evaporation of condensation in the crankcase. That is the reason auto manufacturers recommend changing oil more frequently during cold weather & short trips. The engine, in that case, does not have time to warm up enough to evaporate all the condesation.
Steam is normal (small amount lingering in tube). As long as your oil level is correct & there is no pressure inside the crankcase, your all set.
I would try to describe the noise you heard a bit better though, so everyone can help you. May have just been a stick or branch hidden in the snow that made all the racket.
Old Sep 24, 2006 | 09:14 PM
If it is normal to have some steam escaping from the oil dipstick hole would this taper off at anytime? It really isn't steam escaping though, it seems to me more like exhast. I just started it up again after it had been sitting for a few hours it is still doing it and if I run it without the oil dipstick it sounds like there is some slight clanking and cluncking sounds coming from it.
To describe the sound i orginal heard when riding a bit better it sounded just like when pieces of your belt are flying off and slaming into the belt housing. I cant think of any other way to explain it than that.
Old Sep 24, 2006 | 09:26 PM
Smitty4's Avatar
Yeah, if you run the engine without the dipstick in you'll hear all kinds of noises AND you'll get vapor coming out. That crank is whipping around in there about 18 times / second @ idle, and the downward motion of the piston is going to generate pressure.
I didn't realize you did this with it running! [img]i/expressions/face-icon-small-happy.gif[/img] I'm surprised you didn't get a faceful of oil!!
As for the noise, it's a shot in the dark trying to diagnose from a computer screen. All I have is guesses. Maybe some small rocks got kicked up? If it sounds ok now, and you've checked out the belt & clutches & the inside of the cover for debris, I wouldn't worry too much about it.
Keep an ear on it though, and good luck!
Old Sep 24, 2006 | 09:40 PM
Smitty,
Thanks for the help I think it should be fine but I will keep a close eye on it.
Old Sep 24, 2006 | 10:31 PM
Instigater's Avatar
Sounds like Smitty got you squared away on your problem, so now lets move on to something more a little happier. Where are you that you have snow in Sept.? I AM JEALOUS[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 24, 2006 | 11:11 PM
I live in south central Montana (Billings) and about 40 miles south of Billings in the Pryor Mountains there is already about 3 feet of snow. It was really tough riding because it was hard packed and really difted.
Ty
Old Sep 25, 2006 | 07:47 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
damn, 3 feet. lol. you make sure you keep it all right over there, i dont want any of it if i could help it.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
