pullstart on a grizz
Old Sep 24, 2006 | 07:18 PM
18inches's Avatar
Default pullstart on a grizz
I left the key on and the battery died. I tried to start it manually but couldent get it to turn over. Is there a trick for manually starting the grizz?
Thanks
Old Sep 24, 2006 | 07:55 PM
iamsoup's Avatar
pull it harder, maybe have another person hit the gas if its not efi. check the battery terminals too or recharge battery. my bruin batt died alls i did was have someone hit the gas and i pulled and it started back up
Old Sep 25, 2006 | 12:33 AM
hondabuster's Avatar
One advantage of the yamaha ultramatic trannys..they can be bump started in these situations..if you have a tow strap and another vehicle to pull it. Just put it in high, key on, and have someone pull it. If the back tires just want to slide, instead of rolling, put it in 4wd. No need to go over 10mph, it should start within a few seconds.
Pulling the rope aint fun, but if you slowly pull on the rope, until you feel the compression stroke...stop pulling, let the rope retract(so you can get a full pull), then slowly pull the rope til you feel it engage..then give it a good pull.
Old Sep 25, 2006 | 02:28 AM
RIDER11X's Avatar
AND stand by the front tire to get a better angle on the rope. Pull starting the 660 ain't nearly as rough as people make it out to be.
Old Sep 25, 2006 | 08:37 AM
Barkley's Avatar
To pull start the grizzly, pull up slowly until the rope becomes easy to pull. You will then be past the compression stroke, let the rope back down as far as it will go and give it a yank, it will pull easy now and start right up.
Old Sep 26, 2006 | 10:11 PM
bearwhiz's Avatar
What the last guy said was right but I slowly pull up past that first compression stroke which is usually about 10 inches. I don't let the rope back down but pull hard from there and it starts easily.
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
