Shaving Warrior plastic
Old Sep 29, 2006 | 06:28 PM
Raptor686's Avatar
Default Shaving Warrior plastic
has anyone shaved the front fenders of their warrior? what'd you use to cut them and how much did you cut off and how do you make both sides the same?
Old Sep 29, 2006 | 06:34 PM
1fasstpred's Avatar
instead of cutting them you can take them off and just have the nose piece then if you dont like how it looks cut em
Old Sep 29, 2006 | 07:07 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
No fenders on the one to right
The one on the right is one of my warriors. it didnt have the front fenders on at all.. Just the hood and tank cover.
Old Sep 30, 2006 | 01:13 AM
ZapooMafoo's Avatar
I've shaved my fenders and this is how it looks...
Warrior
Old Sep 30, 2006 | 01:14 AM
ZapooMafoo's Avatar
oh and I used a jig saw
Old Sep 30, 2006 | 03:06 PM
bombrider04's Avatar
wat you can do is use 3m tape and tape off the parts of the fenders and use the line of the tape and make sure they are even by just looking at both of them...then you use a dremel and it will cut the plastics then take the tape off and use sandpaper and sand down the edges til they are smooth using a fine grid paper.
Old Oct 1, 2006 | 12:14 PM
DriverDoyle's Avatar
You can look in my pic page off the wifes warrior..I use a air grinder on anything i shave the plastic on..
Old Oct 1, 2006 | 07:07 PM
recon99's Avatar
Ok, first, the RIGHT way to make sure that both sides the same is to mark off the line you want to cut on one side with some tape, a magic marker, etc. Then cut out a pattern out of some paper, and then lay it over on the other side and mark it off the same. To cut them, I would recommend using a dremel with a cutting wheel if you have access to one, or a sharp utility knife. After you cut them, you will probably want to go over the edges with some sand paper to get them perfectly smooth and even, starting with some rougher grit, then going to the really fine paper to blend it all in.
And i guess this is just personal opinion, but I think warriors look really goofy with cut fenders and the stock headlights. It just reminds me of a goofy looking bird or something with big eyes. Now, if you take the stock headlights off and get an aftermarket set of driving lights it can look really nice.
Joe454
Nov 20, 2020 01:19 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
