banshee clutch lever
sorry i pressed the wrong key.My clutch lever if really hard to pull in. I have an ASV lever and i put in a barnett clutch in about a year ago. I don't know why it is hard and is it bacause of the new clutch or the ASV clutch lever.
The first things to check would be to make sure clutch cable, clutch lever pivot, and clutch cable ball end at lever are all well lubed. I am not familiar with ASV lever but if you put in stiffer clutch springs with the new clutch then that would also give harder lever pull.
I would say it's probably the cable. If you want a great replacement cable, get a Motion Pro Terminator, they are smoother, easier, and last longer than a standard cable for only a few bucks more.
Lou Domenech
Sep 11, 2015 06:35 PM
cdstang
Aug 31, 2015 07:52 AM
