Will other Honda ATC suspen forks fit a ATC 110?
Old Oct 4, 2006 | 07:45 PM
110wannabe's Avatar
Default Will other Honda ATC suspen forks fit a ATC 110?
I am thinking of purchasing a 83 ATC110 but would like some shocks in front. Can you put a suspension fork from lets say a ATC 200 or some other model on a ATC110 so the fork is not so rigid/stiff? Anyone done this before?? If the geometry is close enough it seems possible.
Thanks!
Old Oct 4, 2006 | 08:31 PM
mattshonda's Avatar
i was wondering the same thing
Old Oct 4, 2006 | 09:28 PM
JkAss's Avatar
You can do anything with enough $$$$$.
Old Oct 5, 2006 | 11:39 AM
oldkawi's Avatar
you need to seal the whole front end off an 83 or later suspended 185 or 200 or the entire front end from a 125M they will both bolt on with a little work. Make sure your cables / wiring are the right length after the modification though
Old Oct 5, 2006 | 05:14 PM
HondaAtcRoxz's Avatar
125m's did not have suspension on them... well at least my two that I had did not have any on it. Nor do any other 125's I have seen...
Old Oct 5, 2006 | 09:32 PM
mattshonda's Avatar
mabe not
right now i have worse problems : like stripped threads where the spark plug goes
Old Oct 8, 2006 | 05:45 PM
CYCLONEandATC125M's Avatar
The 1986-87 125m's had front suspension.
Old Oct 11, 2006 | 11:54 AM
oldkawi's Avatar
take the head off, go to a machine shop and get the spark plug hole resized to 14mm from 12mm, then select the proper length of NKG plug, reassemble and your good to go.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
