removing a snapped bolt
Old Oct 9, 2006 | 09:31 AM
bmxatv's Avatar
Default removing a snapped bolt
The bolt that holds the kickplate to the frame has snapped and the kickplate is now sitting back closer to the rear tire. Anyone have any ideas for removal?
Old Oct 9, 2006 | 12:55 PM
JeffinTD's Avatar
Squirt some penetrating oil on it and let it soak, then run to the auto parts store. I've had good luck with the spiral fluted type of bolt extractor. You could also pick up the right size reverse twist drill bit, in hopes that the drill biting on the broken bolt will be enough to back it out.
Take your time to get the hole drilled straight down the middle, and take your time with the extractor, turning it very slowly and apply pressure straight into the hole.
If that doesn't work, is there room to drill and tap the hole for the next size larger bolt?
Old Oct 9, 2006 | 04:40 PM
Slatemd's Avatar
A little heat would help if the rust bust spray fails.
house1
Aug 9, 2015 10:49 PM
Bell21
Jul 28, 2015 06:52 AM
skeets44
Jul 17, 2015 01:04 PM
Desimation2k8
Jul 17, 2015 12:37 AM
Shifts
Jul 3, 2015 07:59 AM
