falcon 250
Old Oct 10, 2006 | 08:04 PM
hoytultratec's Avatar
Default falcon 250
anyone with a falcon 250 out there with any suggestions on cold starting???
its 45 degrees here and this thing is harder than heck to get started, this aauto choke sucks i know is there a secret or a good tip anyone can give???
thanks hoyt
Old Oct 10, 2006 | 09:56 PM
smb05's Avatar
Default falcon 250
hoytultratec,
Have you tried a richer pilot jet?
If your fuel enrichment circuit (auto choke) is not working correctly then consider converting it over to a manual system. I'm not sure if Kazuma makes a manual setup for the 250, but here are a couple ideas for you. I know your carb is not the same as the ones on the gy6, but these conversions should work for your carb also.
ELECTRIC TO MANUAL CHOKE with PICTURES
4) Eliminate automatic choke
Let us know what you come up with.
Good Luck.
SB.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
ErikTheRed
Mar 8, 2006 03:21 PM
TrueGritScott
Mar 7, 2006 02:35 PM
hadaveha
Feb 4, 2006 03:18 AM
