110 carb help
Old Oct 14, 2006 | 08:54 AM
willgg30's Avatar
Default 110 carb help
my 110 idles perfect and starts on the first crank but bogs down and dies when i hit the trottle.
Old Oct 14, 2006 | 09:37 AM
jonnyboy5662's Avatar
I had that same problem with my 185s. I took the carb apart and cleaned it out... I think the main jet was plugged and that's why it did that.
Old Apr 30, 2007 | 05:49 PM
nomoregoodnames's Avatar
again sorry for digging up an old thread but im having the same issue great idle but if you look at the throttle it dies ive taken the carb apart and nothing is clogged im stumped
Old May 6, 2007 | 07:25 PM
3wheelerman's Avatar
Are you running an airfilter on this machine? If you are remove it then see how it runs. If it runs better then I would check your valve lash. It is possible that your valves are not opening all the way as they should be. It would let the machine idle great but as soon as you give it more gas it is forcing more gas in than the valves are letting into the cylinder, causing it to choke out. The intake and exhaust valves should be set at a .002 gap. You could tell if your valve rockers are worn simply by listening to them and you should hear a prominent clicking comming from the valves while it is running. another thing to check would be to see if your choke is sticking.
Old Jun 1, 2007 | 12:11 PM
SMFREY's Avatar
Great piont to check the valve gap
I would also check ignition timing I have done this on my bikes using an inductive timing light and an external battery make sure to set timing to the F mark not the T
If valve lash is good and timing good
Could be engine lean
I would get carb kit clean again Soak in carb cleaner not spray
Install kit
If still issue could need jetting
Thanks
Ray
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
