185 ATV coil
Old Oct 15, 2006 | 12:49 PM
Smitty12345's Avatar
Default 185 ATV coil
Will a coil off of a 200 three wheeler fit/work on a 185 3 wheeler? Thanks
Old Oct 15, 2006 | 01:51 PM
quicksilver's Avatar
i checked over at servicehonda.com's microfiche, and it appears to be the same number for an ATC200 and an ATC185.
Old Oct 15, 2006 | 01:53 PM
Thanks
Old Oct 15, 2006 | 02:12 PM
How can I test my primary stator. Is the primary the top one or the bottom one under the magneto? Thanks Is it correct that the one for the lights can be bad and still not affect spark and running?
Old Oct 16, 2006 | 03:05 AM
well, you'll need a service manual to find the specs, but using and ohm meter, test the wires at the connector outside the case, you're looking for a resistance value to be within the specs in the manual, if there no continuity it's bad. my buddy just had one go bad on his '82 atc200.
Old Oct 16, 2006 | 07:48 AM
Thanks-- I believe someone told me 245 OHMS.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
