13t front sprocket
Old Oct 15, 2006 | 08:52 PM
tamiyacrawler's Avatar
Default 13t front sprocket
What do I need to install a 13t sproket on my latkota? What one should I use? Do I need larger parts or anything?
Old Oct 16, 2006 | 10:55 PM
rolsmojave3's Avatar
You wont' need larger anything. All you will need is a socket (can't remember size off hand). No Parts just a sprocket is needed. Look at rockymountainatv.com, they have good deals on them.
Old Oct 17, 2006 | 06:37 PM
Sweet...do these gears have different teeth that I need to look for to be compatible with my chain?
Old Oct 17, 2006 | 08:11 PM
holeshotz8436's Avatar
you will need a 27mm socket and a impact gun would help alot too......you wont need a biger chain but u may need to loosen urs up a bit.....
Old Oct 18, 2006 | 01:27 PM
bombrider04's Avatar
no the sprocket will fit fine with your chain and won't have to worry abou the teeth fitting inside the chain as they are all 520 o ring chains on them I believe...And all you will have to do is loosen up the carrier to adjust the difference in the chain from the 2 different sprockets.
Old Oct 18, 2006 | 09:38 PM
Actually going up a tooth prolly won't hurt it as my chain is pretty loose. Well I hear this mod wakes it up a bit so I'm hoping for the best. Anyone know where to buy a clamp on air filter?
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
