13t front sprocket
no the sprocket will fit fine with your chain and won't have to worry abou the teeth fitting inside the chain as they are all 520 o ring chains on them I believe...And all you will have to do is loosen up the carrier to adjust the difference in the chain from the 2 different sprockets.
Actually going up a tooth prolly won't hurt it as my chain is pretty loose. Well I hear this mod wakes it up a bit so I'm hoping for the best. Anyone know where to buy a clamp on air filter?
joeyupton
Jul 14, 2015 11:51 AM
