Brute Force 750 ignition switch problem.
Old Oct 16, 2006 | 08:54 AM
kawidave's Avatar
Default Brute Force 750 ignition switch problem.
Hey guys, on my 06 BF when you turn the ignition key off, the power still stays on , how do i test the switch? i have to pull the main fuse under the seat to get the power to go off.???????????? i wonder if there is a continuity check that can be done??????[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Oct 16, 2006 | 12:31 PM
Hayashi's Avatar
When you say the power stays on, I'm assuming you are looking at the digital dash meter that is still turned on, right? It more than likely that the rear BUSS connector by the main wiring harness is shorting due to the electrolysis corrosion. There are lots of posts on this. Do some research and good luck.
skinnyr6
Aug 25, 2023 02:18 AM
Jenn1
Sep 8, 2015 09:16 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Rollin23
Aug 13, 2015 01:12 PM
