coolent in counterbalance oil
Old Oct 18, 2006 | 09:19 PM
pdfd's Avatar
Default coolent in counterbalance oil
I have a 96 Scrambler 400 4x4 2 stroke. I am getting coolant in the counterbalance oil, I have been told that if the headgasket is leaking, and coolant is getting in, then the sparkplug will be clean, and that it will run like crap, and if enough coolant is getting in then it won't run at all, But my atv runs great, the sparkplug is not clean. Is there any other way that coolant can get into the oil? And how bad is this on my atv?
Old Oct 18, 2006 | 09:23 PM
x_scrambler3's Avatar
It is the water pump leaking in. It will cause the counter balance bearing to rust an then break apart an cause alot of damage to the bottom end. I use a syntetic gear oil in mine.
Old Oct 18, 2006 | 09:24 PM
pdfd's Avatar
just the gasket needs to be changed or the entire waterpump?
Old Oct 18, 2006 | 09:25 PM
nothing wrong with head gasket it. It is the water pump it has happend alot to the 400 motors. They seem to get a small leak in to the counter balance cause the pumpo is ran by the counter balance.
Old Oct 18, 2006 | 09:33 PM
pdfd's Avatar
thanks for your help, now I need to find a waterpump..
Old Oct 18, 2006 | 10:23 PM
RickRitter's Avatar
A new waterpump/balancershaft is about $380.
One can be rebuilt for $75.
Seals will cost about $18
A gasket about $8
You can take it apart and fix it at home for around $100 or so .
Rick
There is a special socket you really ought to have too .
Old Oct 18, 2006 | 11:03 PM
pdfd's Avatar
Thanks for the infor rick.... which socket is it that I need? and where can I get it?
Old Oct 19, 2006 | 09:50 AM
WIscrambler's Avatar
I believe he is referring to the socket which is used to remove the reverse-threaded nut behind the counterbalancer. Most people use a hammer and punch to remove the nut. I used a 6" long 3/8" socket extension as a punch and the nut came loose fine. Remember, lefty tighty, righty loosey.
scram5050
Aug 30, 2024 01:39 PM
shortyno11
Feb 22, 2005 01:30 AM
Scotts88
Apr 23, 2003 05:45 PM
Scotts88
Jan 28, 2003 05:10 PM
bowman911
Aug 2, 2002 07:07 PM
