Coolent still Leaking
Old Jul 31, 2002 | 09:12 PM
bowman911's Avatar
Coolent is still leaking out the overflow on my 87 quadracer 250. Every time i try and bleed the system i get more air comming out. What's going on. thanks for any help
Old Jul 31, 2002 | 10:11 PM
spacollie's Avatar
Possible head gasket failure.
Old Jul 31, 2002 | 10:13 PM
spacollie's Avatar
Do a compression check.
Old Jul 31, 2002 | 11:07 PM
WP's Avatar
WP
Sounds like head problems or a head gasket. Pull the head off and check the cylinder and head with a straight edge to see any deformations.
Old Aug 2, 2002 | 05:44 PM
bowman911's Avatar
Was the head gasket, thanks for the help
Old Aug 2, 2002 | 07:07 PM
spacollie's Avatar
Ensure you use the proper torque and torque pattern when installing new gasket. Failure to do so could result in broken new gasket or warped head. You should check your head and jug with a staight edge before installing.
2001 raptor, ct pipe, pro-flow foam, air box mods,
tag x-5, razrs, 12 tooth front.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
