timing on a trx250ex 06
Old Oct 19, 2006 | 09:45 AM
tazman79's Avatar
Default timing on a trx250ex 06
how do you adjust the timing on a trx250ex 2006?
Old Oct 19, 2006 | 12:59 PM
rapittrx450r's Avatar
you cant i dont think , why do you want to? ,,,you could probably order an aftermarket module for different ign curve . if there is an adjustment it would be on the stator side of the engine you may be able to adjust the pulse pick up coil, by loosening the screws that hold the pulse coil moving the plate clockwise or counter clock i really dont think it has an adjustment it might .
Old Oct 19, 2006 | 02:17 PM
tazman79's Avatar
when the values are closed the pistion is down and not up i am tryng to correct this
Old Oct 19, 2006 | 03:42 PM
PaulH's Avatar
Check out his post about adjusting valves... It sounds like something could be wrong, like maybe the cam is installed wrong?
http://forums.atvconnection.com/mess...did/503511.cfm
Old Oct 19, 2006 | 05:03 PM
theres a mark on the flywheel that say T i think theres a plug you take out on left side of engine stator side ,then you can see the flywheel mark from the hole. the T mark is on the flywheel you might have to turn the flywheel line it up with mark on the hole then take the cam gear cover off and you will see a mark on the cam gear a dot it should be pointing straight up there may be an index mark on the head casting above the cam gear to line it up with // with both the T lined up at the hole and the cam gear dot straight up you should be on top dead center if not remove the cam gear bolts and adjust sprocket till it is lined up dont forget to put alittle locktite on the cam gear bolts when re installing and tork them to 10-12 foot pounds. hope this a helpful to you ..
Old Oct 19, 2006 | 05:19 PM
tazman79's Avatar
know where i can get a pdf manual for this
Old Oct 19, 2006 | 08:49 PM
ebay
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
