tightening hub
Old Oct 19, 2006 | 10:53 PM
magnumLover's Avatar
Default tightening hub
I recently had to replace a rear hub on my 2000 polaris magnum 325. i got the new hub and im ready to put it on but im not sure how tight to do it. i dont have a torque rench either if thats needed, thanks
Simon
Old Oct 20, 2006 | 04:37 PM
Director's Avatar
My rear hub nut needs 80 ft/lbs on a 2005 MV7. I would imagine you would need about that also since the axles are probably the same. You definitely should get a torque wrench and also a manual. There are lots of the nuts and bolts that have to be torqued properly. If you over tighten a bolt it becomes brittle and could break, too loose and you can guess. Look on Ebay for a used manual for your bike. Woody
Old Oct 20, 2006 | 09:42 PM
okay i gues ill head out to the store and pick one up, later, and thanks for the help.
Simon
Old Oct 20, 2006 | 11:33 PM
Bad2WD's Avatar
I have a 330 Trailboss with a SRA and it takes 80 ft lb's. If you are going to do your own maintenance and mechanic work you will definetly need a shop manual and tourque wrench that goes up to 200 ft lb's. You may also want to get a 3/8" drive that does inch lb's. Some of the nuts and bolts on mine take less than 10 ft lb's (120 in lb's), it is much easier to do these with a smaller wrench that reads inch punds.
Old Oct 21, 2006 | 12:18 AM
ok im done and i fixed it!!! i am guna be going to the local polaris tommorow and getting the manuals, thanks for the help!
Simon
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Hondapolaris8596
Jul 28, 2016 03:17 PM
firsttimerider
Sep 20, 2015 09:07 PM
Cantbuytime
Aug 16, 2015 09:13 PM
