Rhino 660 will not shift
I have a Rhino 660 and it will not shift. It is in high and the shift lever moves fine, but will not go into low, reverse or neutral. The lever is moving the arm on the side of the tranny. Any one havef any experience with this?
Thanks,
JB
Thanks,
JB
I found the problem. The bolt holding the shift lever on had come loose and the shift leverwas moving, but not actually moving the shift shaft. When looking at it from the side it appeared to be working corretly, but after I rfemoved the cover you coule see from the top that the shaft was not moving.
