Rhino 660 will not shift
Old Oct 22, 2006 | 03:32 PM
jbwrangler's Avatar
Default Rhino 660 will not shift
I have a Rhino 660 and it will not shift. It is in high and the shift lever moves fine, but will not go into low, reverse or neutral. The lever is moving the arm on the side of the tranny. Any one havef any experience with this?
Thanks,
JB
Old Oct 22, 2006 | 05:08 PM
iamsoup's Avatar
if your warranty is not up just take it to the dealer.
Old Oct 23, 2006 | 12:14 AM
jbwrangler's Avatar
I found the problem. The bolt holding the shift lever on had come loose and the shift leverwas moving, but not actually moving the shift shaft. When looking at it from the side it appeared to be working corretly, but after I rfemoved the cover you coule see from the top that the shaft was not moving.
Old Oct 23, 2006 | 12:18 AM
iamsoup's Avatar
Well i hope that will solve the problem, Good luck!
Old Jan 15, 2007 | 08:12 PM
gotsand21's Avatar
i have heard of alot of those bolts have been coming lose. it would be a good idea to cheack it out before you lose the bolt. will send pic of it sone.
Old Jan 15, 2007 | 08:22 PM
wildwest1011's Avatar
lock tite?
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
