Adding LCD to rancher 4x4 manual
Old Oct 23, 2006 | 10:16 AM
USM's Avatar
USM
Default Adding LCD to rancher 4x4 manual
I have seen some post on the possibility of adding the factory lcd to a manual shift rancher. However, does anyone know where I can purchase one of these without paying an arm and a leg through Honda? I have a 2004 Rancher 4x4 350 manual shift. Are there atv salvage yards out there that I may be able to get the LCD screen, harness and all mounting hardware for a descent price?
Old Oct 23, 2006 | 02:06 PM
PaulH's Avatar
I have no idea if it can be done, but what are you considering too expensive? Babbits sells the new LCD, which they call a meter assembly, for $186.90. Course, you will need sensors and wiring, etc.
Old Oct 23, 2006 | 11:30 PM
Rinman's Avatar
If your patient you will probably find a used one on ebay. I see them for the Rincon every now and then. Sometimes the seller is parting one out and would more than likely have everything you would need.
Old Oct 24, 2006 | 09:18 AM
USM's Avatar
USM
Thanks. Do you know if it will have to come off of a Rancher or will other models work? Also, is all of the plugs there on the manual model to where I will be able to just mount it and plug it to the factory harness?
Old Oct 24, 2006 | 11:43 AM
RancherATCrazy's Avatar
Sound like a big pain in the **** for a display, yeah they are nice but you would have to switch the main wiring harness ECU's install speed sensors ect... ect... That is alot of work for a display but If you really want to do it knock yourself out. I would invest my money in go fast parts but that is just my opinion.
Old Oct 24, 2006 | 04:27 PM
ddrumman2004's Avatar
If you are just concerned on speed display, get an inexpensive GPS unit and mount it on the bars. I don't know if the 04 Rancher has the 12v outlet but I know the 05s do and that is what I did. I bought a cheap Garmin Etrex along with a handle bar mount and a 12v adapter. Works pretty good and has to be cheaper than trying to install a factory LCD unit.
Johnny Mac
Aug 15, 2019 03:13 PM
fredrikrosen
Sep 28, 2015 09:58 PM
2many2ride
Sep 27, 2015 04:35 AM
Clint Russell
Sep 25, 2015 03:20 PM
WilliamBos
Sep 22, 2015 04:07 PM
