Help! '96 Polaris tranny rubbing against cover?
Old Oct 24, 2006 | 12:01 AM
bobem12's Avatar
Default Help! '96 Polaris tranny rubbing against cover?
Hi, new here. I bought a '96 polaris trail boss automatic about a month ago. I've started to get this rubbing sound, almost like a tire was rubbing. It only happens when I make a hard right hand turn and shift weight to the left side. I checked and double checked anything I could think of to no avail. I've finally figured out where the noise is coming from I think. Its coming from inside the plastic transmission cover, like something is shifting or moving causing something in the transmission (don't know what it would be) to rub against the cover from the inside. I've yet to remove the cover but I don't know what to look for when I do, not the most knowledgeable about atvs yet. Thanks for any help.
Old Nov 14, 2006 | 07:41 AM
ktm861's Avatar
I have a 96 explorer that just started doing the same thing,I removed the plastic clutch cover and started the engine and it seems that the clutch at idle is coming out to far and hitting the cover.If anyone out there can shed some light on this it would be great.
Old Nov 14, 2006 | 11:30 AM
bobem12's Avatar
kmt, I got a response on a different forum and the guy said that the belt covers can warp from the heat and cause the rubbing also. He said a new cover should fix it. I haven't bought a new one yet because I still haven't actually taken the cover off yet, haven't been home for awhile.
Old Nov 14, 2006 | 11:52 AM
Instigater's Avatar
Heat can warp them as well as the weight of kids feet. Do not let passengers put feet on it!
Old Nov 14, 2006 | 08:55 PM
ktm861's Avatar
My short fix was to take a wood shim and put it inbetween the inner side of plastic cover and the engine.I know it sounds welfare but it better than hearing the knocking noise.I never thought that cover could warp.Thanks for the info.
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
toonces
Jul 11, 2015 12:01 PM
cSchwartz
Jul 9, 2015 02:43 PM
Coryco
Jul 6, 2015 07:30 PM
