New Brute Force Owner
Old Oct 29, 2006 | 03:43 PM
Flashpoint's Avatar
Default New Brute Force Owner
I just bought the brute force 650i yesterday. Is there anything I should know about it?
07 Brute Force 650 4x4i
2500 pound Warn Winch
05 Eiger 400 Manual
Jet Kit
27" Outlaws
2500 pound winch
Highlifter Lift
HMF Exaust
Old Oct 29, 2006 | 05:08 PM
CyberSlacker2001's Avatar
I actually have a 750 but, what kind of riding do you do.. I might have some info for you.
Old Oct 29, 2006 | 10:24 PM
Atvstevo1337's Avatar
Your gonna want to put water proof electrical greese on all the connectors, they are known for letting water in and causeing some short circuits, Get a good CDI and you will be much happyer. Do the regular maintenance as mentioned in your owners manuel. Just the basics.
Old Oct 29, 2006 | 11:37 PM
alwaysride's Avatar
Use LOW gear as much as possible. Use it when pulling, mudding, hillclimbing, etc. Good luck
Old Oct 29, 2006 | 11:49 PM
Kernel's Avatar
Since you got the 650i, good choice [img]i/expressions/face-icon-small-smile.gif[/img], unless you plan on hot-rodding your machine 24/7 and drag racing all the time i wouldnt really bother with a cdi, as on the 650 its much less retarded than the 750's. Mines quite a bit quicker than a 750, not no arm and a leg quicker but enough to win heh. If your coming up to lots of technical crawling, mudding, climbing etc, you have got to get in the habit of switching to 4x4 when you think you are going to need it. My favorite 4x4 system is still Polaris's, although i like the locker on my 650i. Kawasaki really really needs to change their 4x4 system i think, id rather it engage 4wheel drive immediately, not having to worry about moving 2-4ft first. Just perform good maintenace, KEEP YOUR AIR FILTER CLEAN heh, thats more important than alot of folks consider, and keep your oil changed (changing mine every 500miles with Castrol 10w-40.) Reports are the Kawi v-twings are very reliable and durable. OH AND UH, hope you like lookin at the blue sky when you take off [img]i/expressions/face-icon-small-smile.gif[/img] gl
Old Oct 30, 2006 | 12:42 AM
TTP's Avatar
TTP
Keep the air filter clean,,
But more importantly, Drive it like a rental! [img]i/expressions/face-icon-small-wink.gif[/img]
Congrats and have fun!!
Old Oct 30, 2006 | 02:25 PM
Hayashi's Avatar
Read your owner's manual and do everything they say you should do and don't do everything they say your shouldn't do.
Submarining the most efficient way to shroten the life of your Kawi quad - everything from electrical, mechanical, carbueretion, to lubrication will go down hill real fast.
Old Oct 30, 2006 | 06:07 PM
Flashpoint's Avatar
I do all sorts of riding, from sand to mud. Does anyone know if 27" tires will clear without a lift on a 07 Brute 650? And what's the best all around tire out there? I run 27" outlaws on my suzuki, but thats a little more weight than I want on this one. Any replys would be great.
05 Eiger 400 Manual
Jet Kit
27" Outlaws
2500 pound winch
Highlifter Lift
HMF Exaust
Old Oct 30, 2006 | 06:48 PM
montyh's Avatar
27s will clear. i just put 27" Bighorns on my 650i and they fit fine. the only prob is that they almost rub on the inside right rear where the tank and tank guard are. this with stock wheels and 27-12x12 Bighorns which are pretty wide.
monty
Old Oct 30, 2006 | 08:49 PM
Flashpoint's Avatar
Monty,
How do you like the gator tires? Thats what I was thinking of putting on my BF, 27x10x12 fronts and 27x12x12 rear.
