1987 250 Big Red Won't shift into 1st gear PLZ HELP
Old Oct 30, 2006 | 05:05 PM
Texasladi's Avatar
Default 1987 250 Big Red Won't shift into 1st gear PLZ HELP
Everything seems normal, cranks right up...push the shifter and it feels like it has shifted, the neutral light even goes off...but it's not in gear...shifter is good and tight, never had any problems before this....anyone know a good starting point of figuring out what the problem might be?
Old Oct 30, 2006 | 10:43 PM
wrestleu's Avatar
Does it go through all the gears with the trike off?
Old Oct 30, 2006 | 10:57 PM
Texasladi's Avatar
It won't change...running or not...
Old Oct 30, 2006 | 11:02 PM
Williebee's Avatar
If my memory is correct , when you're in neutral you should up shift for 1th through 5th, not down from neutral ; your reverse cable may need adjustment if this is the 87' Honda TRX 250 Big Red ATC ; correct me if i'm wrong ! ...............williebee
Old Oct 31, 2006 | 08:14 AM
Texasladi's Avatar
Well Willie, you're correct but not sure how that has anything to do with my problem. It won't go into gear shifting up or down...shifter moves, but no gear! Just want an idea where to start before tearing into it...
Old Oct 31, 2006 | 04:13 PM
oldkawi's Avatar
your going under the right side case after draining the oil, if your lucky the sping assemby is off your shifter (bottom rear of cranck case) if your not the shift shaft may be broken and that is a HUGE job to change
Old Oct 31, 2006 | 05:54 PM
Texasladi's Avatar
Thanks, we'll try that! We have an old 3 wheeler we kept for parts so hubby said he'll take that one apart first to see how everything is, then check the "good" one [img]i/expressions/face-icon-small-smile.gif[/img] We'll probably need some parts out of the old one anyway!
Old Nov 24, 2006 | 07:53 AM
spcasml's Avatar
did that fix it if no email me il tell you whats wrong at socasml@yahoo.com
Old Nov 24, 2006 | 08:32 AM
Texasladi's Avatar
Thanks...I think hubby found what is wrong. The rear axle is stripped...so it was changing gears, but just couldn't go anywhere! I have one ordered, hope it works!
Njrider1230
Jul 29, 2023 05:16 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
colt1126
Aug 18, 2015 08:27 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
