New belt= Squeal and hard to shift.
Old Oct 31, 2006 | 10:15 PM
Aryan1889's Avatar
Default New belt= Squeal and hard to shift.
Well I put a new belt on my Dads 03 650 Prairie and Now the things squeals and it hard to shift in and out of gear. Yes I put it on the correct way and all. Whats the deal?
Old Oct 31, 2006 | 10:40 PM
kodiac1's Avatar
If it's squealing in gear it has to be too tight.Did you make sure the deflection was no less than 22mm?When I went to a 700 belt and set the deflection at 22 mine squealed ever so slightly at idle in gear but has since stopped.
02 650 camo
Old Nov 1, 2006 | 08:55 AM
ColdKaw's Avatar
How do you set the deflection when installing a new belt? I've heard that it's a difficult procedure.
Thanks
Old Nov 1, 2006 | 06:37 PM
Hayashi's Avatar
You remove a shim (washer) to make the belt tighter, or add a shim to make the belt looser. There should be a few shims on the fixed sheave's shaft of the driven converter. You should remove/add one at a time and check/measure.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Whitelx1
Oct 2, 2015 10:55 PM
