MiD Range Warrior
Old Aug 29, 1999 | 01:45 AM
MXrider's Avatar
What could i pu on my 1996 Warrior to give me big boost in MID range? I dont want any more low end. I would rather have alot of MID and a little top than a lot of MID and a little low.
Old Aug 30, 1999 | 11:41 PM
TULLEY366's Avatar
YOU DIDN'T MENTION WHAT YOU HAVE DONE TO IT ALL READY. A GOOD SUPERTRAPP TYPE MUFFLER THAT YOUR CAN ADJUST IS A GREAT WAY TO GET THER TYPE OF POWER YOU WANT.
Old Aug 31, 1999 | 10:14 PM
PamFalcioni's Avatar
I'd probably start with a different muffler -- I agree, the Supertrapp is the best for most applications. Then a mild cam would give you more midrange and a little better top-end. The only down side is that it will take away a little bit of torque. Not a problem, unless you're running big tires and mudding the bike.
Make sure the cam you're buying is a MILD one. The Warrior responds pretty abruptly to high lift cams.
Powroll and White Brothers both list mild Warrior cams. The White Brothers cam has to run Heavy Duty springs, the Powroll cam can be run with stock valve springs.
After that, you can run a vented airbox lid. Make sure to rejet!
You'll get about a 15 - 20% horsepower gain, mainly midrange and top end.
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
