The dirty Carb
Old Nov 9, 2006 | 10:14 PM
Skeeterdone's Avatar
Default The dirty Carb
I've got an 2001 Kodiak, that was been running great. Just went out to start it, it started and was sluggish on the throttle reponce. I tried to let it idle and it died and wouldn't start. So I started to pull the carb off. I've rebuilt serveral car carb's before and motorcycle carb's before but by looking a diagram this one looks internally to have quite a few small parts inside.
Question is how hard are they to pull apart and clean? I did see that you had to make sure during dissasembing that you make sure you note the number of times the piolot screw is turned out from the seated position.
Any coaching would be appriciated..Do you just pull the three or 4 screwa out of the side to remove the throttle. Also do you unscrew the choke from the side. I've got everything else already disconnected.
Old Nov 10, 2006 | 02:41 AM
bombrider04's Avatar
Well what i usually do when taking apart my carb is I turn the gas off at the petcock and run the rest of the gas out of the carb then diconnect it from the intake...now if you take the carb off flip it over and unscrew the screws holding on the bowl of the carb and inside there you will see a main jet and a pilot jet take them boh out and clean them with carb cleaner making sure you can see light through all of the holes and yes make sure you count the turns when dissasembling and reassembling the jets so the cabr will be dialed in correctly...then make sure that the intake tube is seated correctly and tight when putting it back on and all should be good but if you don't have much gas in the tank drain the rest incase you have dirt in the tank...also check to see if you are running out of gas...for the future if you aren't going to ride the quad for a while turn the gas on off and run it out of the carb so there won't be a buildup of junk in the jets and rest of the carb
Old Nov 10, 2006 | 02:42 AM
here is a pic of your carb
http://www.ronniesmailorder.com/fich...=258&year=2001
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
