Clutch kit for Brute force 750
clutch kit is not going to give your power back just changes shift points the stall speed of your cvt add a moose module -- copperhead vdi to recover your power with those tires you really dont need clutch kit at the most just change primary-secondary springs
Your stock clutch setup isn't nearly the best for stock tires, much less oversized tires.
Personally I like the Dalton kit and there's a noticeable power-to-the-ground difference with the kit installed.
