Kawasaki750 brute, bent shift fork #2 question
Has anyone experienced a bent shift fork on a bruteforce? I ran into someone and jambed it forward, ever since it pops in and out in low range... anyone help? info? I've adjusted the shift linkage, but still the same thing. The service manual talks about the fork getting bent.....has anyone ever experienced it? I sure appreciate any help I can get here
Check your main engine mount on the very bottom of the engine, Its a big bolt, goes all the way across the frame. I'll bet money its loose and hopefully you haven't tore your frame out yet. I tore the bottom mount and one rear just from it being loose. The problem is the engine actually sits different and it causes reverse probs. After the engine is set and tight readjust your shifter linkage and I'll bet you are fixed....
Njrider1230
Jul 29, 2023 05:16 AM
