Kawasaki750 brute, bent shift fork #2 question
Old Nov 13, 2006 | 07:35 AM
lnsmman58's Avatar
Default Kawasaki750 brute, bent shift fork #2 question
Has anyone experienced a bent shift fork on a bruteforce? I ran into someone and jambed it forward, ever since it pops in and out in low range... anyone help? info? I've adjusted the shift linkage, but still the same thing. The service manual talks about the fork getting bent.....has anyone ever experienced it? I sure appreciate any help I can get here
Old Jan 19, 2009 | 09:19 PM
lnsmman58's Avatar
Default Kawasaki750 brute, bent shift fork #2 question"></title><script src=
Check your main engine mount on the very bottom of the engine, Its a big bolt, goes all the way across the frame. I'll bet money its loose and hopefully you haven't tore your frame out yet. I tore the bottom mount and one rear just from it being loose. The problem is the engine actually sits different and it causes reverse probs. After the engine is set and tight readjust your shifter linkage and I'll bet you are fixed....
Njrider1230
Jul 29, 2023 05:16 AM
Jenn1
Sep 8, 2015 09:16 AM
DFWSRT8
Aug 20, 2015 09:24 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
heath legg
Jul 24, 2015 01:01 PM
