Kazuma 150 Wiring Help
Old Nov 19, 2006 | 04:04 PM
Jushavinfun's Avatar
Default Kazuma 150 Wiring Help
My Kazuma 150 decided not to start yesterday. Push the start button and nothing. No click, no response. I am electrically OK to troubleshoot but have no diagram to trace. It is not the brake interlock and not the start button itself. Battery voltage is good. My manual does not have a schematic. Unit is two years old. I would appreciate some help!
Old Nov 19, 2006 | 06:04 PM
billl2099's Avatar
did you clean your battery cables yet?
Old Nov 19, 2006 | 08:05 PM
Yes, I removed the cables, put a steel wire brush and put back on. The battery read 12.28v so I put it on the charger.
Old Nov 20, 2006 | 11:01 PM
RacewayATV's Avatar
Jushavinfun
If you call me when you are with the ATV we can do some test to see if we can help you out!
John.
Old Nov 21, 2006 | 10:25 AM
mylil150's Avatar
It could be your voltage regulator. Mine was bad from the time I got it but it would start then just drain the battery because it ran off of it. Unclipped the regulator and plugged it back in and it started to smoke. It wouldn't start after that or anything. It was the wrong regulator on mine so got the right one and chose it by looking at pictures. So maybe the regulator went bad on yours I dunno know lol.
Old Nov 22, 2006 | 08:37 AM
Thanks John. I will call you after the holidays.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
400H0
10
Aug 20, 2015 07:34 PM
frostphase
Aug 19, 2015 07:11 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
DeFox500
Jul 26, 2015 06:32 PM
