1998 Warrior miss
Old Nov 19, 2006 | 07:23 PM
cheitman's Avatar
Default 1998 Warrior miss
I have a Warior that I bought used and have since replaced the CDI, Stator, Cluthch and rebuilt the engine with new rod, crank, pistons rings, and valves. The quad has a Suppertrapp Pipe, K&N filter and uni filters in the airbox. It runs great and has tons of power and torque, however, has a miss in the upper RPM's. Do these have a rev limiter that comes in really early. It has a 13 front sproket with 22" tires and has run close to 60 next to a buddy, but misfiring from about 48mph and up.
Old Nov 19, 2006 | 09:43 PM
recon99's Avatar
Warriors actually don't have any rev limiter at all from the factory. The closest thing to a rev limiter is floating the valves haha.
When was the last time the valves were adjusted? Did you ever take a look at the spark plug after doing one of those high rpm runs, to see if maybe the jetting is off?
Old Nov 20, 2006 | 12:50 AM
cheitman's Avatar
I thought the CDI had a rev limiter. the valves are adjusted per spec. I did rebuild the carb with the old motor and it had larger jet in it already. It seems as though this problem occured after rebuilding the carb, which was coincidental to finding the old motor low on compression just plain loose and tired.
Old Nov 20, 2006 | 09:09 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
it may not be a miss... it may be water i nthe gas
Old Nov 22, 2006 | 11:47 AM
cheitman's Avatar
Any other suggestions?
Old Nov 24, 2006 | 12:08 AM
cheitman's Avatar
TTT
Old Nov 24, 2006 | 12:17 AM
recon99's Avatar
like I said in my first post, did you ever check the spark plug after one of the runs when it's acting up, to see what the jetting is at? It could be too lean, too rich, or have something clogging up the main jet.
95wolv
Sep 27, 2024 12:00 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
