Battery drain
I'd try unplugging electrical components one at a time, and check after each one to see if the current draw stops.
Haha, or disconnect your battery, connect 120 ac from an extension cord, and see what smokes! Then you know where that parasitic draw was coming from [img]i/expressions/face-icon-small-wink.gif[/img]
yes, the rectifier/regulator is a good place to start. You could start by pulling fuses one at a time first, that will help narrow it down to which circuit. Look into a manual if you need the wiring diagrams.
