Battery drain
Old Nov 19, 2006 | 10:55 PM
Totten's Avatar
Default Battery drain
I have a honda 350 es that goes dead all the time. I used a multimeter and it is showing a draw on the battery when its off. Any suggestions on how to locate the draw
Old Nov 20, 2006 | 02:25 AM
recon99's Avatar
I'd try unplugging electrical components one at a time, and check after each one to see if the current draw stops.
Haha, or disconnect your battery, connect 120 ac from an extension cord, and see what smokes! Then you know where that parasitic draw was coming from [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 20, 2006 | 07:24 AM
HondaMechanic's Avatar
The ES model has a draw which runs the dash memory & clock .. It is rated at 1ma max.
Old Nov 20, 2006 | 08:48 AM
Totten's Avatar
Thx for the reply. I am aware of the 1 ma for the clock. But I am showing about 5 ma.
Old Nov 20, 2006 | 12:15 PM
5mA is to high .. You will have to start un-plugging couplers 1 at a time while watching your amp meter ..Starting with the regulator/rectifier ...
Old Nov 20, 2006 | 04:40 PM
quicksilver's Avatar
yes, the rectifier/regulator is a good place to start. You could start by pulling fuses one at a time first, that will help narrow it down to which circuit. Look into a manual if you need the wiring diagrams.
Old Nov 21, 2006 | 02:52 AM
Totten's Avatar
If I disconnect the regulator and the problem stops does that mean the regulator is bad?
Polarisman1123
Sep 13, 2015 10:06 AM
Ronbo6270
Aug 6, 2015 11:54 PM
momma's bike
Aug 6, 2015 09:49 AM
Shifts
Jul 3, 2015 07:59 AM
