2003 lt-80
Old Nov 21, 2006 | 12:43 AM
dps1000's Avatar
Default 2003 lt-80
i just got my daughter a 2003 lt-80 on fri. we went riding sat and sun and it was great, i got home late and left it on the truck lastnight. tonight when i got home i started it up and it cant even pull it self, has anyone had this happen to them or anyone know what is wrn,,,,, please help we are to go out of town riding this weekend ............ [img]i/expressions/face-icon-small-sad.gif[/img]
thanks
Old Nov 21, 2006 | 10:35 AM
LT80's Avatar
LT80 Expert
Default 2003 lt-80
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
It's a plugged jet (prolly the pilot jet).
Clean the carb and remove both jets and blow out well.
Old Nov 21, 2006 | 03:01 PM
dps1000's Avatar
Default 2003 lt-80
thanks will try tonight and let you know if it works
Old Nov 22, 2006 | 01:09 AM
dps1000's Avatar
Default 2003 lt-80
before i took off the carb i pulled off the little cover for the belt and it had a lot of water in it i got it all out and dried it with a airhose and it works fine, i noticed that several bolts are missing on the case for the belt and part of the gasket was missing so water could get in there. thank you for the help
also how do you check the oil, and how do i add oil if i need to ?????
Old Nov 22, 2006 | 10:29 AM
LT80's Avatar
LT80 Expert
Default 2003 lt-80
In front of the front sprocket, there is a bolt you take out. The fill is on top. Fill till oil seeps out the hole.
10-40 oil is fine.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
