Starter button
Anybody had any trouble with the gray starter push button on their Raptor? I couldn't get the button to crank the starter yesterday. The batter had a full charge, but the starter button itself was not working. I pulled of the entire headlight/kill switch/starter button assembly (which is new this season) and cleaned it. Nothing. So I jump started it to ride today, but after a few laps on the track, I tried the switch again and it worked. It has been working since I left the track. Weird.
It's not necessarily a bad button just because nothing happens when you push it. It could just as easily be a broken/disconnected wire between the starter button, the power source, and the solenoid. Or it could even be a bad solenoid as well.
You said you jump started it? Do you mean you got it rolling and popped the clutch, or did you actually use jumper cables to get it to start?
fordfaithful21
Dec 7, 2015 05:52 PM
