If you have worked on a Scrambler 4x4 transmission please help ...
Old Dec 5, 2006 | 11:37 PM
jbp's Avatar
jbp
Default If you have worked on a Scrambler 4x4 transmission please help ...
2001 Scrambler 500 4x4
Well now I know why forward did not work. Small bits of plastic (no idea where they came from) where in the area under the gear indicator switch. They got packed into the pocket that the shift fork slides into when you select the forward gear. The plastic chips keep the shift fork from going in all the way which cause the engagement dog to not fully seat against the forward gear. The cogs on the face of the forward gear got worn down so far that forward would no longer engage. I bought the machine like this so I'm not sure exactly what happened. He said it started popping out of gear and eventually forward was gone. So I need a new forward gear. My question is how much slop should the engagement dog have on the reverse shaft? The engagement dog slides on the reverse shaft. I can wiggle the engagement dog a little. I'm guessing there is supposed to be a little slop since the dog is intended to slide freely up and down the shaft.
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
