200X
Old Dec 6, 2006 | 12:57 AM
BAJAxFANATIC's Avatar
Default 200X
i want to put a wider axel and longer swing arm on the 200x. where might i be able to find these parts?
Old Dec 7, 2006 | 08:12 PM
haywoodjalikme's Avatar
Default 200X
Keep your eye on eBay, they pop up on there once in a while.
Jeff
Old Dec 9, 2006 | 04:55 PM
carlw's Avatar
Default 200X
any welding shop will do this for you for you. it is a easy job if you have the tools. they just cop the carrier off and weld in a extetion.
durablue makes extended axles.or you can use wheel spacer. i have been running a set of aluminum wheel spacers for 8 years on my 3 wheeler with not a single problem. they are 3" each for a total of 6" wider. they totaly change the bikes handeling.you will like it.
ebay is also a very good sorce for 3 wheeler parts.
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
88Warrior
ATC 3-Wheelers
Aug 7, 2001 07:27 PM
hrc200x
ATC 3-Wheelers
Feb 7, 2001 08:46 PM
bigmanm
Jun 28, 2000 10:34 PM
200X
ATC 3-Wheelers
May 24, 2000 10:47 PM
