200X
200X
any welding shop will do this for you for you. it is a easy job if you have the tools. they just cop the carrier off and weld in a extetion.
durablue makes extended axles.or you can use wheel spacer. i have been running a set of aluminum wheel spacers for 8 years on my 3 wheeler with not a single problem. they are 3" each for a total of 6" wider. they totaly change the bikes handeling.you will like it.
ebay is also a very good sorce for 3 wheeler parts.
