Any mods to put MV7 springs on sportsman
Old Dec 8, 2006 | 03:22 AM
noooooo's Avatar
Default Any mods to put MV7 springs on sportsman
I just got my MV7 front springs for my 2005 sportsman 800 and was going to ask the guys who put them on their machines if any modifications were needed to make them fit ? Thanks
Old Dec 8, 2006 | 08:22 AM
spyder6's Avatar
no mods needed, you'll probebly need a spring compressor though
Old Dec 8, 2006 | 11:18 AM
Instigater's Avatar
No mods needed, I have tryed a spring compressor. Honestly I feel it is more dangerous. I got one from Autozone and it was too bulky for this setup. You can do it without a spring compressor, by taking the tie rod and lower a-arm off of the strut housing. Then, loosen the 2 clamp bolts. The spring tension is not bad at all. Remove the upper strut nut. Do the spring swap, then put the a-arm on and the wheel. Then lower the quad onto the wheels, the quad weight will compress the spring as you guide the upper in to the mount. Put the upper strut nut on. Push the strut down until it bottoms out. Tighten the clamp bolts. Then remove wheel if you want to, to put tie rod and cotter pins back in.
Old Dec 8, 2006 | 12:45 PM
sheepdogMSP8117's Avatar
Don't know how much different your springs and ATV might differ from what I did. But HERE is what I did. Good luck!
Old Dec 9, 2006 | 02:12 AM
noooooo's Avatar
Thanks guys for all the help. Hopefully I get time this weekend to install them. Also the label on the bubble wrap the MV7 springs come in say the spring rate is 125-170 pounds.
Old Dec 10, 2006 | 12:32 AM
Wow, thats stiff!
Old Dec 10, 2006 | 09:53 AM
spyder6's Avatar
thats what she said.
Old Dec 10, 2006 | 01:06 PM
noooooo's Avatar
Yeah I know, I read the MV7 springs were 75-170 pounds. Even the local Polaris dealer was wrong. Anyway, I hope they sag like my original springs do. I hope that when these sag they will be real close to what I am looking for.
Old Dec 11, 2006 | 11:07 PM
partteeman's Avatar
I installed the MV7 springs on my 05 700efi. The ride is perfect. The bike does not bottom out nearly as often and is more stable at higher speeds. Oh... I did the install without a spring compressor and it took about 20 minutes total. Simple install.
Old Dec 12, 2006 | 02:48 PM
noooooo's Avatar
I agree!! I finally got them put on. I have only ridden it in the cul-de-sac but it is not as stiff as I was afraid of it being. There is no way they are 125-170 pounds like the bubble wrap label says. I believe it is going to be close to perfect especially with the front spring preloaders from t-m-2. I will have the option to crank up the preloader when plowing snow. Mario's customer service at t-m-2 is phenominal.
Cole Hadden
Jun 15, 2025 09:05 AM
mtdewmn
Jan 19, 2017 12:13 PM
Schneider
Jul 24, 2015 05:05 PM
Jul 22, 2015 05:00 AM
Mphillips
Jul 2, 2015 07:20 PM
