250x handeling improvement?
Old Dec 11, 2006 | 11:06 PM
400exnram's Avatar
Default 250x handeling improvement?
I no i can make the front of a 250x wider with 400ex a arms and shocks with the shock mount bracket. can i make the back wider with a 400ex axle or are they the same. also the back shock is shot an looking for a cheap replacement anyone have one or no what other than stock would work keeping the rear the same hight as stock? thanks
Old Dec 12, 2006 | 10:20 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If you want to widern a few inches, just get some wider rims that have a greater offset, and some wider tires.
I run ITP Holeshot XC's on ITP T9 rims, and the quad ends up +3" in back and +2" in front.
Old Dec 12, 2006 | 10:31 AM
asfasasu3's Avatar
A 400 axle will work, but a spacer has to be made to tighten it up. The carrier is narrower on the 300 than the 400.
Old Dec 12, 2006 | 11:39 PM
400exnram's Avatar
whats the off set of the rear rims? i have the 400ex a arms and shocks so thats what i want to do in the front but ill deff do rims in the back
Old Dec 13, 2006 | 08:52 AM
asfasasu3's Avatar
We use 1 1/2" spacers on ours and it make the rear just a little wider than the front, with the stock wheels. I don't know what wheels are available, but if you got them wider by an inch and have an inch less backspacing, that would work fairly good. Or something close to that anyways. Your looking for about 1" to 2" per side to make them even. (front and rear)
Old Dec 13, 2006 | 10:12 AM
Red Rider
The 9X9 rim has a 3+6 offset.
Old Dec 13, 2006 | 09:30 PM
1988fast250x's Avatar
Well the raptor 660 rear shock works but it has to be off of the 2001 model.. and u have 2 get a longer hose 2 mount the resivour.. But im fairly confident that the warrior 350 shock works and the hose is plenty long enouf on that bike
Bratman2
Aug 6, 2022 01:42 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
antiguogrumete
Sep 5, 2015 03:41 AM
4464
Aug 21, 2015 01:46 AM
bpegram84
Jul 22, 2015 08:15 AM
