Warrior cylinder walls..
Old Sep 9, 1999 | 08:32 AM
lordmik's Avatar
How far can you bore a Warrior's cylinder walls before you encounter hot spots and overall loss in reliability? Many places can send me a piston any size I want, but I don't know how far I can punch this thing before I run into trouble. Thanks in advance.
Michael "Lordmik" Magee
Stranded on a tropical island, for now...
Old Sep 9, 1999 | 04:28 PM
Heapster's Avatar
On the stock jug, I'd not go over .060 overbore. This is what I did to get 400cc from my Warrior motor and bore alone takes it up to 366cc I believe. Combine that with a stroker crank (5.6mm) and you get the 400cc with only minor case relief work. Any more of a stroker and you need more lower end case work for crank clearance.
Let me know if you've got any other questions.
Heapster
400cc Wicked Warrior - 400ex Eater?
Old Sep 10, 1999 | 01:46 AM
thumper4x4's Avatar
I`ve been running a .080" over bore. In my 95 Wolverine for 2 years now, with 11:1 compression. With no problems. Thats as high as you can go with out a modified sleeve, and case modification.
Good luck...
Dewhound
Apr 20, 2017 02:25 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
