Magnum 425 carb rebiud?
Old Dec 18, 2006 | 06:23 PM
Heinz01's Avatar
Default Magnum 425 carb rebiud?
Anyone know how hard it is to rebuild a carb on a 1995 magnum 425 4x4? And can you give some pointers on rebuilding it?
Old Dec 18, 2006 | 09:25 PM
scrammersam's Avatar
have a clean area where you are working and theres lots of small parts that could go missing. its not to hard..having lots of light helps
Old Dec 18, 2006 | 10:46 PM
ftwflh's Avatar
Get you a new needle valve and seat along with a new diaphram befire you start.Then just take the jets out and clean everything real good.Pay close attintion to the pilot jet and be sure ALL the little holes are clear.
Old Dec 19, 2006 | 08:21 AM
Heinz01's Avatar
Thanks guys ,will give it a try.
Old Dec 19, 2006 | 05:48 PM
cornbread2's Avatar
Make sure you replace ther slide needle and nozzle. These two parts wear quickly on the 425's. After they wear it will run rich.
Old Dec 19, 2006 | 07:20 PM
Heinz01's Avatar
Do the needle, nozzle, needle valve and seat, and diaphram all come in a rebuild kit?
Old Dec 19, 2006 | 07:21 PM
Heinz01's Avatar
I forgot to add that it does run rich. And does bog down around half to 3/4 throttle.
Old Dec 19, 2006 | 08:59 PM
ftwflh's Avatar
I dont think you can get a complete kit and Polaris will gig you good on the parts because you got to have them.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
