TM45, throttle return... not coming back to idle properly
Old Dec 24, 2006 | 02:15 AM
Johnnyairtime's Avatar
Default TM45, throttle return... not coming back to idle properly
Okay...
Now that I got the DS out of storage... and she runs beautifully...
The return spring on the carb won't bring it back to idle all the way. I have to snap the throttle open for it to return, or do it by hand and it comes back. Seems the tension on the spring needs to be a tad more... and it'll be perfect.
Ideas??? How to gain a little bit more tension, or if there's a way to make the throttle come back easier, as the cable has the slack it needs when closed.
HURRY carb gurus!!! I'm on my way out Monday!!!
Thanks, and Happy Holidays!!
Old Dec 24, 2006 | 03:02 AM
DuneMe's Avatar
Heard of them getting caught-up on the seat. . . you may want to do a search or cut your seat pan a little.
Old Dec 24, 2006 | 03:06 AM
Yup... new of that, and this is all with the seat off the quad... nothing binding.
It's something to do with the carb itself. Or the spring.
Old Dec 24, 2006 | 03:37 AM
DuneMe's Avatar
Do you have an accel. pump enabled? Check the linkage?
How's the slide look. Not gummed up?? I know. . . obvious stuff.
Old Dec 24, 2006 | 08:43 AM
eRo's Avatar
eRo
try lubricating your throttle cable, and check your thumb throttle, maybe something is binding or "hanging up" on something somewhere
Old Dec 24, 2006 | 12:17 PM
Hmmm....
I'll check the slide, could be something.
Accel pump is enabled, linkage is okay.
Twist throttle with pretty much new cable. No binding.
... this quad is like brand new (check my garage) ... so it's not the common issue things to look for. Since it's been sitting, the slide is a good thought. It doesn't stick when it's ridden, it's only seat off in the garage kind of thing. You give it a slow rev and it will not return. When it's ridden, the jarring and vibration helps it return and you really don't notice it. Or, you snap the throttle open and then closed and it won't stick... it returns okay.
Merry Christmas Eve.... [img]i/expressions/face-icon-small-smile.gif[/img]
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
TORK
Jul 30, 2015 04:19 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
trx430ex
Jul 7, 2000 05:53 AM
