GIOVANNI 150cc
Old Dec 26, 2006 | 01:09 PM
cgerm's Avatar
Default GIOVANNI 150cc
Just got a GIO 150cc and can't seem to get it fired up. Turns over fine but I don't see any fuel going from the fuel **** to the carb....I assume the open position for the fuel **** is pointing down? not sure because the manual isn't really clear...In any event I tried all three positions and get no fuel through the hose...also where is the choke on this ATV?
Old Dec 26, 2006 | 01:56 PM
carlw's Avatar
when i have a fuel valve that will not flow fuel. i remove the valve and investige.
to remove the valve on a ATV i would remove the tank. dump the fuel back into a jug or a fire ant hill. then remove the valve and see whats up with it.
Old Dec 26, 2006 | 03:21 PM
hoytultratec's Avatar
sounds like a bad shut off valve, go to a small engine shop and get a new one,i did it on the redcat150 works fine now. just put it on in place of the one thats on the frame,easy fix.
dannytas
Sep 26, 2017 06:31 PM
frostphase
Aug 19, 2015 07:11 PM
Jaster94
3) General Discussions..
May 29, 2015 08:45 AM
elmer119
May 24, 2015 10:51 AM
poolhustler
Nov 11, 2003 01:38 PM
