Baja 50cc Problem
Old Dec 27, 2006 | 08:28 PM
WATERJETDUDE's Avatar
Default Baja 50cc Problem
Hope everyone had a great Christmas.
I bought my 5 yr old little girl a Baja 50cc from PepBoys. All seems to fine, with one exception. There is a choke lever located behind the fuel shutoff valve. The choke lever has 3 positons, one position I presume is no choke, another is half choke, and I ma guessing the other is full choke. It will start fine in either the 1st or 2nd position and runs OK in the second, which I am assuming is the half-choke. At any time I switch over the the third position, which I am assuming is where it should be when running in normal mode, the engine will die. This occurs even if I have warmed it up for a half-hour. I can ALMOST keep it running if I give it some throttle, but it still dies. The idle speed is fine
My question is this....Is this symptomatic of a carb needing adjustment of the fuel/air mixture? I know your never quite sure what you'll get with the Chinese quads, but the quality seems to be decent. The manual is a totally different story and does not even reference the choke, or the location of the fuel/air screw. I only knew where the choke was when the PepBoys tech told me to start it "all the way up", let it run 2 minutes, "move it to the middle" and run it 15 minutes and then "move it all the way down".
Any help is appreciated! Thank You.
Old Dec 27, 2006 | 09:14 PM
trailridercamden's Avatar
I had the same problem where it didn't seen to run full power unless the choke was on and after cleaning the jets it started working right.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
firsttimerider
3) General Discussions..
Aug 9, 2015 09:54 AM
TheHood
Jul 26, 2015 09:51 AM
hondarider1234
Jul 21, 2015 11:53 PM
