intermittent spark
Old Dec 27, 2006 | 11:04 PM
325expadition's Avatar
Default intermittent spark
my raptor has spark some times only when you let off the start buton nospark at all when holding start buton. Once it finaly cranks it runs good but is hard to start. What would be the most likly cause of the simptoms? thanks
Old Feb 7, 2007 | 04:54 PM
saturnman's Avatar
i was wondering if you have solved your problem yet. i have a timberwolf with the same problem and it has confounded me. i hope you are having better luck if you are i would appreciate some help
Old Feb 7, 2007 | 11:25 PM
yes mine turned out to be bad conectors and ground. some times it will be the stator or a bad battery will do it some times to
Old Feb 8, 2007 | 12:37 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Make sure both ends of your positive and ground cables are clean and tight.Weak batteries make that exact thing happen often. The voltage drop across is to high (not enought to the cdi) to fire the ign when being loaded with the starter. A new battery will usually fix it. Try jumping it with a running car or truck.
Old Feb 8, 2007 | 09:33 AM
saturnman's Avatar
thanks guys i have a new battery and cables but i have been suspicious of wiring problems i have the wiring harness out i will have to tear it open and inspect it carefully. how will i know if my stator is bad my local yamaha tech checked my pickup and said it was fine do you know what kind of volt or ohm readings i should be getting. thanks again.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Elkaholic
Sep 6, 2015 02:44 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
