Giovanni 150cc continued...
Old Dec 29, 2006 | 02:22 PM
cgerm's Avatar
Default Giovanni 150cc continued...
I took the fuel **** apart and cleaned out...I now have gas flowing through the tube
into the top of the carb...seems ok...I also have a tube from the bottom of the carb
that goes nowhere and seems to drain gas when I have the fuel **** open...is this
normal or is this suppose to be connected somewhere...in any
event I still can't get it started...any idea where the choke is on these?
Old Dec 29, 2006 | 02:55 PM
rodneygt's Avatar
The tube on the bottom of the carb (bowl) is for draining the bowl. There should be a screw right next to it on the bottom of the bowl for shutting off the flow.
Alot of 150s have the so-called electric choke. If you have some wires going to an apparatus on the left side (as you sit on it) of the carb, then you have this. I dont think it's really a choke at all but something that lets more gas in during idle mode until heat causes it to shut off the flow. I believe it only functions when you are not operating the throttle. (not a very good explanation but you can find more on it with the search function)
Rodney
Old Dec 29, 2006 | 04:55 PM
cgerm's Avatar
Hey thanks rodneygt, I closed the screw and it started up...sweet!
dannytas
Sep 26, 2017 06:31 PM
frostphase
Aug 19, 2015 07:11 PM
Jaster94
3) General Discussions..
May 29, 2015 08:45 AM
elmer119
May 24, 2015 10:51 AM
poolhustler
Nov 11, 2003 01:38 PM
