Heated grips
Old Dec 30, 2006 | 10:50 AM
downeaster's Avatar
Default Heated grips
How much trouble is it to put on heated grips, and where do you make the
connections. Do connection instructions come in the replacement grips
package.
Old Dec 30, 2006 | 12:43 PM
hondabuster's Avatar
It takes just a bit of electrical knowledge, and instructions come with all grips that i know of.
One thing they dont usually said to do, is put a in-line fuse in the postive side of the circuit. That should be done, and a 3 or 5 amp fuse is good.
Depending on which quad you have, the accesory port is a good place to tap into an already fuse proected circuit, which is only on with the key.
The nuetral light, or reverse light circuit also works good, as those are hot, while key is on. Both use a switch to ground, to enable the light. Make sure you tap into the wire, before the bulb, and not after, or the light will be on when the grips are on. Think about adding a thumb warmer too, because youll find out how cold that thumb gets , and those hand warmers dont help the thumb.
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
black_thunder
Sep 7, 2015 01:24 AM
