tire size 400ex
Old Jan 1, 2007 | 10:21 PM
jed250's Avatar
Default tire size 400ex
What tire size is stock for a 400ex? I want to stick with the 20's (I'm getting holeshots) but dont know what the other numbers mean.
20 x 11-9
20 x 11-10
Which one should I get? Will it matter what I order?
Old Jan 1, 2007 | 10:47 PM
JimmyHoffa's Avatar
Here's an example:
20= outer diameter
11= width of tread pattern
9= rim diameter
The first # (20, in this example) can be any size you see fit. 20" is a good all-around track/woods size. It's the outer diameter of the tire.
The second # (11, in the example) is the width of the tread pattern, and only matters slightly. A 20x11-9 tire will fit on a 10" wide rim.
The last # (the number you question) is crucial. The 20X11-10 tire WILL NOT fit on stock 400ex rear rims. Trust me. I own one. It defines the bead diameter (the diameter of the inside of the tire) which, on a 400ex rear rim is NINE INCHES.
The verdict?: You need the 20x11-9 tire-- if you run the stock rear rims.
Old Jan 2, 2007 | 01:13 AM
tubbby's Avatar
If you are looking for a good place to get an e-brake for a 400ex go to www.servicehonda.com, they have reasonable prices and lots of oem honda parts. I also have a 400ex and I have removed my e-brake altogether
and put a block off plate in its place. I had to replace my e-brake twice because moisture kept getting into it and locking it up. My advice is to block it off. I keep a large squeeze clamp under my 400ex and I clamp the front brake handle to my grip and it works just fine.
Old Jan 2, 2007 | 02:23 PM
jed250's Avatar
http://cgi.ebay.ca/RED-ATV-TIRE-BLOW...hippingPayment
What do you guys think of those tires? They are cheaper than other tires and I'm assuming it is because they are colourful and nobody wants them. I figure I would go with red to match my 400ex.
Old Jan 2, 2007 | 03:06 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Notice that it says Holeshot TYPE......these are NOT genuine ITP Holeshots! These are some cheapie KNOCKOFF.............
I wouldn't do it! You have no idea what you will be getting. You would probably be best off with the Holeshot H-D's, seeing you are an eastern trail rider. Spend the money and get the genuine article! 22X7-10 front and 20X11-9 rear
http://www.itptires.com/sportatv/holeshot_hd.html
Old Jan 2, 2007 | 06:23 PM
jed250's Avatar
I looked at the tire size that I have on now and they are 20 x 11 x 10 Kendas.
I think I will get some Holeshot XCR (Cross country and trail)
http://www.ronniesmailorder.com/cat....es&newsub=true
I live in Canada and there is a bit of snow outside right now. I'd like to also climb hills in pits and stuff. I figure any tire will do that but some better than others. What is the cheapest place to order from? Is that RonniesMailOrder.com place a good place to buy from?
Old Jan 2, 2007 | 07:12 PM
Red Rider
So you must have some aftermarket rims???? Stock rims are 9".
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 24, 2015 01:00 PM
