Question on Kazuma 90cc motor
Old Jan 7, 2007 | 04:28 PM
DarrenMc32's Avatar
Default Question on Kazuma 90cc motor
Does anyone know if this motor shares the same gearbox as the 50cc motor? The reason I ask is that I'd like to see if our 90cc atv can be operated with gears like the 50cc atv from Kazuma. Even though the specs claim its a CVT, the 90 seems to simply be locked in one gear. Could this be the case? If so, is there any way to "unlock" this, add a gear lever and have the four speeds like the 50? Any help would be appreciated.
Thanks, Darren.
Old Jan 7, 2007 | 07:32 PM
2manytoys's Avatar
You are right. It is a fixed gear and you can not make it a semi automatic. If you want to gear it down to have better bottom end then you need to change the sprockets. You can also look on ebay for a semi auto motor or just buy another one and sell this one. Most people change the gears to have better bottom end but still have good top end speed.
Old Jan 7, 2007 | 08:30 PM
DarrenMc32's Avatar
Thanks. The motor seems to have enough low end power but it can't be good for the engine to run the high rpms all the time once he gets going. I've seen the motors on ebay to replace this one but they don't have electric start and the kick start would hit the fender. Where else can I look to get a motor like this with gears. Thanks, Darren.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Bratman2
Aug 6, 2022 01:42 AM
vlkster
Jul 28, 2015 11:35 AM
ghost civic
Jul 15, 2015 10:48 PM
