blaster right side cover
Ok call me an dumba#* but how in the heck do you get the right side cover off. I am trying to remove the gear for the oil injector and I have removed all the bolts from the cover and I can not get the dang thing off. I can get it loose back by the kick starter shaft but the front will not budge. Am I not being force full enough. I do not want to screw up the side cover by trying to force it off. Is there a trick to getting this off or do I need to pull out the BFH and smack it.
Please help this challenged idiot.
Double check and make sure there isnt any covers that just snap on and cover a screw. Your prolly just not giving it enough elbow grease but dont be mad at me if you break something! [img]i/expressions/face-icon-small-smile.gif[/img]
It should come off pretty easily. You might have forgotten a bolt. If you are sure you got all the bolts off maybe try and pry it off. I wouldn't use alot of force, you may damage something. Also make sure you pull it off evenly.
Thanks guys. I got it off. I wasn't giving it enough force. Got the rebuild completed and it is running like a top. I made my own oil blockoff kit................it was easy and cheap..............cost me 6.95 for the new clutch cover gasket.
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
